VW passat 2005 1.9 tdi fault code 00650
VAG Error Code: 00650
Fault Location:
Clutch Pedal Switch (F36) - Open Circuit/Short Circuit to Positive/Implausible Signal
Possible Cause:
Wiring/Connector(s).
Clutch Pedal Switch (F36).
Possible Solutions:
As taken from my new https://volkswagenforum.com/forum/ge...oftware-34973/
Fault Location:
Possible Cause:
Possible Solutions:
