Transmission problem
Old Dec 1, 2009 | 02:26 PM
Shanna7463's Avatar
Default Transmission problem
Hey Everyone, I have an 05 Passat GLS 1.8T w/ a little over 72k miles on it. One morning, I experienced jerking when it would switch gears, and then after a few minutes it stopped switching gears all together and the check engine light came on. I took it to my mechanic and he said I need a new transmission. Is this normal for a Passat with such low miles on it??
I've had cars with 120+k miles on them, and they never needed a new transmission! I'm hoping the VW will see that I got a bad seed, and maybe help with the costs of the new transmission. Anyone ever heard of this actually happening?
Thanks,
Shanna "Soon-to-be a VW hater"
Old Dec 3, 2009 | 10:25 PM
inpupram73's Avatar
I have the same issue in my transmission. I replaced the k1 spring assembly and that fixed it, for a day. Now the problem is back. I have no idea what it is.
Old Dec 17, 2009 | 02:11 AM
Scoottecope's Avatar
Thanks for the reply but I found the problem. The plastic connector under the truck came off the arm from the transmission with the gear in drive. Therefore the truck wouldnt start. Cobbed up a fix becasue they wanted like 80 for an entire cable from the shift to the tranny when all I really needed was the small plastic piece on the end.
ledzep
Aug 27, 2008 11:40 PM
kinib
May 19, 2007 05:23 PM
libertyh
Apr 27, 2007 02:47 AM
brighteyes
Jan 14, 2007 11:46 PM
dcspletter
Dec 27, 2006 11:50 PM
