stalling diesel
Old Sep 23, 2008 | 08:52 AM
gord's Avatar
Default stalling diesel
help,
stalls, crank foir ever then starts, then stalls, see air in line??? pump seals???95 turbo diesel passat 1.9 i think
Old Sep 23, 2008 | 07:44 PM
Jrailer's Avatar
Default RE: stalling diesel
try a filter first
Old Sep 24, 2008 | 10:14 AM
gord's Avatar
replaced the fuel filter. i had this happen before but this time the filter did not help. at first i though it did as it started after cranking quite a while and it seemed ok. after it ran for about ten minutes (idle) it started to buck and stall. it will start again after cranking for what seems like forever but it runs very rough and will not sustain higher RPM's. it stalls eventually. it will again start after long cranking
Old Sep 24, 2008 | 07:22 PM
Jrailer's Avatar
you are pulling air in somwhere
pull the sending unit out i think there is a pre filter on the fuel pickup
Heathered
Aug 16, 2008 09:10 AM
rach924
Mar 24, 2008 09:02 AM
beebop13
Aug 19, 2007 12:29 PM
sommerjetta
Jun 12, 2007 08:57 AM
Adam Cooke
Feb 17, 2006 08:03 AM
