replace pass side mirror
Old May 14, 2010 | 10:30 AM
EVANGELIONHD's Avatar
Default replace pass side mirror
i went to the mall and when i came back my side mirror was shattered...
anyhow of how can i replace it? i just need to change the glass itself the casing is almost ok. they also crack the signal but im not in the hurry of replacing that..
i saw the glass mirror in ebay but i was wondering how can i change it and not just glue it in top of the other one... i dont wanna loose the defrost function on it.
thank you all
Old May 25, 2010 | 12:01 PM
Avril's Avatar
  1. Step 1
    Buy the replacement mirror, making sure that it is an exact match to your vehicle's make, model and year. You can order it through your dealership. If you'd like to save more money, you can order a mirror online or buy one from a junkyard or a salvage yard that sells auto parts.
  2. Step 2
    Roll down your window and shut your vehicle off.
  3. Step 3
    Disconnect the battery's negative cable. This is important, because there is a risk of electrocution if you do not perform this step.
  4. Step 4
    Take off the interior door panel by using your pry tool to remove the trim pieces. Then use the screwdriver to remove the screws holding the panel in place. You may have to remove a corner trim piece before the door panel lifts off.
  5. Step 5
    Unplug the wiring harness if you have power-controlled mirrors. If you have manual roll-down windows, skip this step.
  6. Step 6
    Take out the mirror bolts with either a socket wrench or a nut driver, so that you can remove the entire mirror assembly from the car.
  7. Step 7
    Separate the actual mirror from the mirror assembly. Use a torx driver to extract the screws, and then pry the plastic tabs on the backing until the two pieces separate.
  8. Step 8
    Attach the new mirror to the assembly by snapping it onto the backing with the tabs.
  9. Step 9
    Put the new mirror, attached to the backing, into the mirror assembly.
  10. Step 10
    Reverse the steps to reinstall the entire mirror assembly back onto the vehicle.
Good Luck
infinitron
Apr 22, 2009 07:01 PM
RConway
Apr 2, 2007 10:55 PM
RConway
Apr 2, 2007 10:53 PM
RConway
Apr 2, 2007 10:50 PM
b8john
Jul 22, 2006 09:10 PM
