Rear Brake Pads on Passat
Old Mar 29, 2006 | 02:52 PM
klugej's Avatar
Default Rear Brake Pads on Passat
I was rotating tires on my wifes 2003 Passat, 4 Motion. The brake pads in the front do not look worn at all but the rear pads should be replaced now. The car has about 30K on it. Is this normal?
Any special tools required to replace pads? Can I use C clamp to compress the caliper back in??
Thank You, John
Old Mar 29, 2006 | 06:07 PM
p_mister's Avatar
Default RE: Rear Brake Pads on Passat
to replace the pads it is just like any other car. nothing to special (use a C clap) ummm and for the kwick ware i dont know. do you do alot of stoping hard???
tony
sliver108
Feb 19, 2009 04:45 PM
bagel
Mar 16, 2008 08:56 PM
bokkafa
Mar 12, 2008 12:54 PM
Xanadu
Nov 21, 2007 08:44 AM
gbtr6
Feb 10, 2006 01:37 AM
