problems at 2000 RPMs
Old Aug 11, 2009 | 01:00 PM
Ria987's Avatar
Default problems at 2000 RPMs
It seems like my Passat is not shifting properly. it is a '99, automatic. Around 40mph and 60 mph, at 2000 rpm , there is a plateau in the power, and I have to pump the gas, or lay down hard on the gas, to get past 2000 rpm, and then we cruise along fine.
Sometimes I have had problems of it seeming to downshift when going slowly, resulting in lack of power, and a stuttering feeling.
What could this be? Big problem or an easy fix somewhere?
Also probably unrelated, when i turn the steering wheel at low speeds it creaks under the hood. maybe just needs more grease somewhere along there.
THANKS for any help!!
Old Aug 12, 2009 | 12:25 PM
leftlanedave's Avatar
Sounds like you and i have the same issues? look at my post " passatt no power"..
I have been told it needs computer recalibrated? but not sure just about ready to take to dealer and get raped!
Old Aug 12, 2009 | 12:51 PM
Ria987's Avatar
maybe we do. Although mine comes and goes sometimes. I called my mechanic, and of course my three drives since then have been perfect, no problems. Im sure it is not gone for good.
Old Aug 12, 2009 | 04:00 PM
turbopass0208's Avatar
Member
Go and get your transmission fluid and filter changed. If this is not functioning correctly, it will make your enginenot run correctly either and it will cause one or both of them to fail. It did this to me on my 02 passat. The engine was bad and after I replaced it and the next day the transmission went out because the transmission tried to compensate and when the engine failed and was replaced it caused the transmission to fail. Save yourself a lot of money and headaches and do the preventitive maintinace.
Old Aug 24, 2009 | 07:57 PM
gtaryder08's Avatar
My 98 passat 1.8T just started today but its stick and in each gear after 3000 RPM i floor it and it goes no where couple days ago it ran fine and storng hitting high RPMs but just today it lost all its power i dont know what to do !!!!
RJ100
Jan 14, 2010 02:24 PM
devhen
Jul 10, 2009 07:08 PM
BlueKitsune
Nov 10, 2008 07:52 PM
jocrook2
Mar 16, 2008 01:23 PM
jakejetta
Dec 31, 2006 07:04 PM
