-   -   POWER WINDOW NOISE (https://volkswagenforum.com/forum/volkswagen-passat-cc-21/power-window-noise-1996/)
HOODSTER Dec 3, 2006 11:55 PM
POWER WINDOW NOISE
JUST PURCHASED A 96 PASSAT TDI WITH THE DRIVERS WIDOW TAPED UP!.REMOVED DOOR TRIM E.T.C AND OPERATED SWITCH.mOTOR RUNS FINE AND MOVES RGULATOR DOWN BUT AT THE TOP 3 INCHES OF TRAVEL SEEMS TO MISS THE TEETH ON REGULATOR MAKING A CLICKING SOUND.LOOKS LIKE A BIT OF A JOB TO REMOVE MOTOR FOR INSPECTION.IS THE MOTOR GEAR MADE OF PLASTIC AND DO THEY BREAK OR AM I BARKING UP THE WRONG TREE ?PLEASE HELP MY WIFE WANTS TO USE HER NEW CAR AND ITS COLD HERE !![&:]
rmgvw Dec 4, 2006 04:22 PM
RE: POWER WINDOW NOISE
hello, your window regulator drive gear is plastic and do wear down. you can buy a repair cable kit from the dealer... hope this helps. robert.
