Passat 2000 have problem 00545
I have problem with gearbox automatic not going to 3 gear some times..
I saw at computer code 00545 engin _ transmission electrical connection 31_10 open or short to ground intermittent please help with foto and catalogue Shadei200@hotmail.com |
Default Welcome to Volkswagen Forum - Rules & Recommendations VAG Error Code: 00545Fault Location: Engine/Transmission Electrical Connection - Open Circuit/Short Circuit to Earth Possible Cause: Fuse(s). Wiring/Connector(s) from/to Engine Control Module (ECM) and Transmission Control Module (TCM) faulty. Possible Solutions: Check/Replace Fuse(s). Check/Replace Wiring/Connector(s) from/to Engine Control Module (ECM) and Transmission Control Module (TCM). Read Measuring Value Blocks (MVB). Check for loose Engine Control Module (ECM) power relay. Special Notes: If stored in combination with 01312/01314, these must be rectified first. Transmission Diagnostic Procedures As taken from my new EOBD II Fault Codes Software Post approved. Post moved to the correct section as OP can't read sub forum tiles. ;) |
| All times are GMT -5. The time now is 12:54 AM. |
