Passat 2000 have problem 00545
I have problem with gearbox automatic not going to 3 gear some times..
I saw at computer
code 00545 engin _ transmission electrical connection 31_10 open or short to ground intermittent
please help with foto and catalogue
Shadei200@hotmail.com
I saw at computer
Fault Location:
Engine/Transmission Electrical Connection - Open Circuit/Short Circuit to Earth
Possible Cause:
Fuse(s).
Wiring/Connector(s) from/to Engine Control Module (ECM) and Transmission Control Module (TCM) faulty.
Possible Solutions:
Check/Replace Fuse(s).
Check/Replace Wiring/Connector(s) from/to Engine Control Module (ECM) and Transmission Control Module (TCM).
Check for loose Engine Control Module (ECM) power relay.
Special Notes:
If stored in combination with 01312/01314, these must be rectified first.
Transmission Diagnostic Procedures
Post approved.
Post moved to the correct section as OP can't read sub forum tiles.
VAG Error Code: 00545
Fault Location:
Possible Cause:
Fuse(s).
Possible Solutions:
Special Notes:
Post approved.
RingoTheBeetle
Jan 23, 2020 11:17 AM
