Oil Pressure on 2002 1.8L Turbo
Oil pressure light began going on intermittently immediately after the car was repaired for a new Cam Chain Tightener, water pump, timing belt, and rebuilt Turbo. Fearful the engine might have sludge, I also had the mechanic drop the pan and clean the pick-up screen while he was doing everything else. Mechanic reported slight sludging when he tore into the engine.
Light goes on when under moderate load, and will cycle off if I shift to neutral and coast for a couple seconds. Any ideas? [align=left] [/align] |
