Oil in overfill tank
Old Mar 4, 2007 | 10:26 PM
kidrockblastz's Avatar
Default Oil in overfill tank
I have a 1993 Passat GLZ VR6 and it had oil in the antifreeze overfill tank. There is no trace of water or antifreeze in the oil though. I replaced the oil cooler, flushed the system with water untill it was clean. I drove it for about 20 miles and checked it and again there was oil in the tank. anything else i can check? flush the system couple more times?
Old Mar 24, 2007 | 10:07 AM
lou7200's Avatar
Default RE: Oil in overfill tank
Have a block test done to eliminate head gasket trouble probability.You don't mention the color of the oil or if the car is automatic.I have seen automatic trans. leak thru the radiator core since the fluid travels there for heat exchange.Also some coolants or anti-rust and water pump lubricants may leave a residue that is similar to oil.Let us know what the outcome is.Good luck
efrainnn
Apr 22, 2014 12:38 PM
Rob1uk
Oct 16, 2008 04:11 PM
mtnbug
Jan 18, 2008 11:47 AM
daplantinga
Oct 25, 2007 09:43 PM
lorner
May 15, 2007 02:20 PM
