Oil Filter Location - New Passat 2.0T
Can someone tell me where the oil filter is located on the 2006/2007 Passat 2.0T? I searched topside &underneath and can't find it? Have you ever changed one?
RE: Oil Filter Location - New Passat 2.0T
Hello
The oil filters on the 3C passat's are now paper element type and are located in the housingunder the black plasticcap on the front of the engine with the 30mm nut on top Hope this helps Chris |
actually its a 36mm located under the splash shield remove that u will see the black plastic oil filter housing also replace the seal thats in that housing...
:)Thanks guys. Actually I found it through a tip from a local auto parts dealer. I did the oil/filter change.
Now I'm wondering why they went back to the replaceable cartridge insert. Reminds me of way back when (50's vintage cars). BobP |
