Oil Cooler "O" Ring Replacement
1999 VW Passat, 1.8T, 20 valve, AEB engine. Can the nut holding the oil cooler in place be removed with a standard socket and/or wrench? I need to replace the "O" ring asI have a massive oil leak. Does not appear to be gasket that mounts to engine at this point.
RE: Oil Cooler "O" Ring Replacement
comes off very easy. theoil switch is above the cooler check that is isnt leaking
