oil in coolant fluid oil cooler ?
Old 01-18-2011, 06:48 AM
Default oil in coolant fluid oil cooler ?
Hi!
My car: VW Passat B5 (1.9TDi AJM 85kW 1999)
My problem: oil in coolant fluid
Possible causes:
-head of the engine (head gasket was changed recently)
-oil cooler
Any other possibilities?
So I detach oil cooler from the cooling system and clean coolant fluid. After few days I clean coolant fluid again (I guess rest of the oil which was circulating) and after that I did not find oil in coolant fluid anymore so I think problem was the oil cooler.
Now I should replace it but I have little dilemma about finding the right one.
See this picture – my oil cooler is on right:
In online catalogues I can find both as recommended for my car.
Even in ETKA catalogue is under passat schemes the left one:
Is possible that both oil coolers are fitting into my passat?
Here is one more picture from the Internet for comparison:
[/quote]
*my friend has left one in Golf IV and in my passat is that one in the middle
Old 01-25-2011, 11:34 AM
Oil cooler replaced - I used same as was there before (with parallel leads).
I drove around 100km+ and no oil in coolant fluid and no oil losses from engine.
Problem solved - broken oil cooler.
STUMPED
05-14-2012 09:54 PM
04-10-2011 10:23 AM
ginnifer
06-18-2009 08:18 PM
rolandor
12-08-2007 07:02 PM
sirhcsenrab
04-03-2006 02:10 PM
Quick Reply: oil in coolant fluid oil cooler ?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
