-   -   Oil consumption info (https://volkswagenforum.com/forum/volkswagen-passat-cc-21/oil-consumption-info-30703/)
piyush123 Feb 15, 2011 12:23 AM
As many of you know and have same problem i bet there is an oil consumption with 2.0T FSI engines. I had an issue with mine and it seamed to me like its alot of oil so i had dealer check it out.
At first they told me it was acceptable to evaporate one quart per 1000 miles witch still seamed too much oil to me. After talk with service manager he told me he would do oil consumption test.
They changed oil in it and marked it down and i had to drive 630 miles then come back for them to drain oil and weight it up. After 630 miles i went in and they told me VW agreed that it was too much and they will have car for two days to change piston rings on it.
So if anyone is having same issue and has warranty on their cars go in and have them do consumption test on it. There is nothing to loose, you will get oil change for free at least...
Hope it helps someone!
