MAP sensor location
I have a 2012 Passat with the 2.5l and I can not find any information about where the MAP sensor is located.
1 Attachment(s)
Welcome to the forum. Attachment 2443
How do you know the MAP sensor is giving a problem have you had your motor scanned with VAG-COM\VCDS? The MAP sensor will be on the inlet tubing as it measures Manifold Absolute Pressure (MAP). Just Google for a picture? https://volkswagenforum.com/forum/ne...gnature-34185/ |
I had the code pulled and is what it said.
What error code was shown?
