Malfunction Indicator Lamp
Old Sep 13, 2008 | 08:14 PM
cuffy1947's Avatar
Default Malfunction Indicator Lamp
Have a 2002 Passat and the Malfunction Indicator Lamp is steady on. The manual says when blinking it is a catalytic converter problem. Because it is steady on should I consider this an immediate problem. It has to be driven 300 miles on Monday morning. Should I go to VW beforeor consider this is not a major issue? Thanks
Old Sep 13, 2008 | 09:30 PM
Jrailer's Avatar
Default RE: Malfunction Indicator Lamp
should be ok if its not blinking
get it pulled as soon as you can might just be a vacume leak or a loose gas cap or somthing minor
2littlebadgers
Aug 6, 2008 09:07 AM
gumbee
Jun 26, 2008 10:30 PM
roger8144
Sep 3, 2007 09:50 AM
dpilotpaul
May 1, 2007 07:38 PM
bcichowlas
Mar 3, 2007 09:57 PM
