Interior lighting - no power the whole system
Since the beginning: The whole interior lighting (front and rear) are revolted and refused to shine. I came to this plus the lack of cable which powers all the lights.
This cable goes from the terminal 30a behind the fuses, and must have some connection on the road where it spreads to other wires and then enter the line "Down Right Side - at the feet of the driver." Since the connector on the bottom of the right upright beam goes up, the main lights on the roof liner and the canopies of these two. Now, yes - at this junction at the bottom right-hand pillar is no longer a plus. Question: Where can it be any where power connector (+) terminal 30a is distributed on the rear lights and possibly something else. It is proposed that it should be somewhere under the driver's legs in the bundle on the floor, but if anyone knows the exact location of this connector?? I've seen something like that on the other side near the passenger's feet and there may be something like this? Vulnerability deleted - reason - the connector 7 wires red - black about 20 cm from the comfort of the module harness turned into tiny little pieces. Soldered - it works |
