-   -   inner door panel removal on 2006 passat (https://volkswagenforum.com/forum/volkswagen-passat-cc-21/inner-door-panel-removal-2006-passat-35082/)
tomt56 Aug 18, 2012 03:12 PM
I have been unable to proceed with the front passenger door panel removal because I can't remove the door latch trim. Its hung up on the rear where the door latch is. I would like a complete set of instructions on how to remove the entire panel. Thanks! Tomt.
Keithuk Aug 18, 2012 07:16 PM
1 Attachment(s)
Welcome to the forum. Attachment 3044
How to remove the door cards, side view mirror housings, or window switch on a VW Passat.
tomt56 Aug 19, 2012 07:13 AM
Secondary metal door panel
Thank you Keith. I have removed the panel tho I did break off two of the clips which I have repaired already. Now I am facing the secondary panel and I have removed the bolts holding it but it still doesnt want to come off. Something is holding it in the rear center area. What other stuff needs to be disconnected? I'm trying to punch out a dent in the lower part of the door. It is a 2006 passat. Thanks so much.
Keithuk Aug 19, 2012 08:52 AM
I'm not sure what else you have to remove as I'm not that familar with the Passat doors, sorry.
jhonsilver459 Oct 2, 2012 03:56 AM
How do I change headlight bulb on a passat 2006?
I have a 2006 Passat and the passenger side headlight bulb went out. How do you replace the light bulb?
Keithuk Oct 2, 2012 05:21 AM
How to change the headlight bulbs on VW Passat B5.5
VW Passat TDI 2005-2006 headlight bulb conversion or changing your headlight bulb
