Help to Connect the ECU
HI
If anybody can help me to connect the ECU from "vw passat 1800 turbo model 2004, type of ECU awt". i need a Service Manual, photo, linkoranything that can helpto figure out witch wire goes where from the carto the ECU. Thank you... |
RE: Help to Connect the ECU
can you be a little more specific like what wire or why are trying to connect to the ecu, because there may be an easier way
I have changed my engine with vw passat turbo engine and i dont know exactly how to connect the wires to ECU and all the wires.
you may have to change the ecu too.
