Hard manual shift between 1st & 2nd
Hi
My first post here, as I'm a relatively new VW owner. Bought a 2013 Passat highline TDI manual 6 months ago. I love the car but I've gradually noticed that my shifting between 1st and 2nd is not so smooth. It's basically because it's quite a hard pull into 2nd gear, much more so than shifting into any other gear. I was wondering if this is basically the standard with all cars of the type, or if this is something that should be looked into. Thanks |
1 Attachment(s)
Welcome to the forum. Attachment 2759
Are you used to driving manual gearboxes? Providing your pushing the clutch pedal down far enough there shouldn't be a problem. If its under warranty take it to a dealer and see what they say. Post moved to the correct section. https://volkswagenforum.com/forum/ne...gnature-34185/ |
