Engine Oil 2010 Passat 2.0T?
Old Apr 10, 2011 | 07:39 PM
mwr1964's Avatar
Default Engine Oil 2010 Passat 2.0T?
Manual says 5W-40, but if not available you can use 5W-30 both synthetic. The dealer uses 5W-30 (Penzoil Platinum). Is this OK to use rather than 5W-40?
The dealer changes it every 10,000 miles and I take advantage of the maintenance plan, but I change it myself once in between so it gets changed every 5,000 miles. Just curious about the viscosity.
Old Apr 11, 2011 | 03:34 AM
elrocco88's Avatar
yeah, 5w 30 is fine. I use that in my jetta. Although I plan on putting in 5w 40 because with 5w 30 i get lots of ticking noise from the engine. Your newer engine can go further with out an oil change. but mine i have to replace it every 3k to 4k.
hope this helps
kimgayoung
Apr 30, 2015 11:56 AM
dave@nedustoff.com
Feb 28, 2010 07:57 PM
JL
Mar 27, 2008 09:57 AM
sirhcsenrab
Apr 3, 2006 02:10 PM
