Direction Signal Problems
Old Apr 11, 2008 | 12:13 PM
PA_Jim's Avatar
Default Direction Signal Problems
A few weeks ago my directional started making a rapid clicking/buzzing noise when I applied pressure to the signal lever. It would stop when the signal was completely on or off. Then it started making the noise even when the signal was off. The noise is coming from the center of the dash board, behind the radio somewhere. Today,there were times when the signals did not work at all when I put them on, and sometimes it did work fine. I do not want to take the car to the dealer to get fixed. Is this something I could do myself? What needs to be replaced? Thanks for your help!
Old Apr 11, 2008 | 06:40 PM
Jrailer's Avatar
Default RE: Direction Signal Problems
you need a new hazzard switch
the flasher relay is part of the switch
veryeasy to change
Z40sx
Jul 28, 2007 05:04 PM
Jetta57
May 18, 2007 11:39 AM
skidooracer_22
Apr 20, 2006 05:51 PM
nocturnal
Jan 26, 2006 12:56 AM
Z40sx
Jan 23, 2006 12:24 AM
