-   -   Check Engine Fault (https://volkswagenforum.com/forum/volkswagen-passat-cc-21/check-engine-fault-36668/)
SouthernGent Dec 4, 2014 11:35 AM
Check Engine Fault
Recently, I purchased a 2007 Passat 2.0 Turbo. After driving the car for about a week, the check engine light came on. I had the code checked and it said the #4 cylinder was misfiring. I changed the spark plugs and the #4 ignition coil. I then had the code cleared. Now, the light is back on.
I don't know what else to check or change. Any ideas on what could be causing this error?
Thanks
Keithuk Dec 4, 2014 07:05 PM
1 Attachment(s)
Welcome to the forum. Attachment 2551
SouthernGent Dec 6, 2014 01:39 PM
Solved
Figured this one out. It is my gascap seal. The seal is apparently gone and causes a "check engine" error. Has to be replaced.
Expensive damned thing too.
slcoc2010 Apr 30, 2015 11:50 AM
My check engine light has become a regular fixture on my console; 2006 2.0L Passat. I was told initially that is was due to an oil leak. That was fixed, light came back. Now 3 different shops are telling me it's a temp sensor issue. They said if the car's temp is staying regular to not worry about it.
