CEL Light on Have Codes
Old Nov 27, 2011 | 06:32 PM
mblanco2000's Avatar
Default CEL Light on Have Codes
My check engine light came on this evening. Went over to the auto store and got them to pull the codes for me.
P0171
Definition: System too lean - bank 1 (Cylinder number 1 denotes bank 1)
Explanation: Low fuel pressure or volume
Probable cause: Faulty Ho2S (Heated oxygen sensor)
Large Vacuum leak
Faulty MAF Sensor
P0507
Definition: Idle Air control system RPM higher than expected
Explanation: Large Vacuum leak on engine
Probable cause: Throttle plate misadjusted or damaged
Faulty IAC valve
The idle is a touch rough when I am stopped. Also it seems when I am off the gas it does not decelerate as it normally does, the speed stays more constant.
In the past I think I had a bad O2 sensor, and would suspect that is the cause, but wanted to check w/ you guys before I buy parts. Help is appreciated, thanks.
Old Nov 28, 2011 | 07:30 AM
VAG Error Code: 16555
EOBD II Error Code: P0171
Fault Location:
Fuel trim (FT), System too lean, bank 1
Possible Cause:
Intake/exhaust leak.
Secondary air injection (AIR) system.
Manifold absolute pressure (MAP) sensor (G71).
Mass air flow (MAF) sensor (G70).
Fuel pressure/pump.
Injector(s).
Evaporation emission (EVAP) canister purge valve.
Heated oxygen sensor (HO2S) (G39).
Possible Solutions:
In the vast majority of cases, simply cleaning the Mass air flow (MAF) sensor (G70) does the trick. It's best to take it off and spray it with electronics cleaner or brake cleaner. Inspect all vacuum and PCV hoses, replace if necessary. Check for a dirty fuel filter and proper fuel pressure.
VAG Error Code: 16891
EOBD II Error Code: P0507
Fault Location:
Idle speed control (ISC) system (G28) - rpm higher than expected
Possible Cause:
Throttle control unit.
As taken from my Free EODB II Error Codes Software
Old Nov 28, 2011 | 04:01 PM
How easy is it to change the fuel filter? I know I have never touched it yet. I believe it is in the gas tank.
Also what should I do about the 507 code? thanks
Old Nov 28, 2011 | 07:13 PM
I can't tell you were the fuel filter is located but its not in the fuel top its probably under the car somewhere.
There is no 507 it should be a 4 digital number so
Fault Location:
Possible Cause:
You really need to find someone with VAG-COM\VCDS to do an Autoscan and post the report in here?
Old Dec 2, 2011 | 08:09 AM
Well I cleaned the MAF sensor this morning. It is still idling a bit rough. Do you have to remove the plastic air cowling that holds the air filter to get to the TB to clean it? Is there a better way? I always have trouble removing that cowling....
Old Dec 2, 2011 | 09:35 AM
Old Dec 2, 2011 | 11:02 PM
  #7
Does anyone have a write up or information on getting to the Throttle Body on a Passat 2.0t? Mine is the 2007 model.
Thanks
Old Dec 3, 2011 | 04:53 AM
  #8
Old Dec 5, 2011 | 09:04 AM
  #9
Thanks for the link. That is great. However, on the 2007 2.0t Passat where is the throttle body? It looks like it might be against the firewall on the passenger side. Tough placement to get to. Let me know if I am wrong on this, I sure hope so.
Old Dec 5, 2011 | 09:28 AM
  #10
Well I don't know where you live but I find the Haynes manuals very useful for doing DIY jobs an they are reasonably priced?
VW Passat Manuals
In fact I bought VW Golf & Jetta Petrol & Diesel (04 - 07) 53 to 07 which is the Mk5 Golf but alot of the things will be the same until that make a Mk6 Golf manual.
