Brake Lights 01 Passat
Old Mar 18, 2008 | 04:19 PM
paul04's Avatar
Default Brake Lights 01 Passat
My 2001 Passat passenger side, brake lights are out. I checked the bulbs they are fine, and the directional is still working on that side. I'm trying to figure out which fuse would be for the brake lights, but can not seem to locate the fuse. Any ideas/suggestions or has anyone had this problem? Thks
Old Mar 18, 2008 | 04:57 PM
bagel's Avatar
Default RE: Brake Lights 01 Passat
so your left tailight works, then switch out the bulbs and if it doesn't work still then it's a wiring issue. There is a recall on brake lights as far the brake pedal switch not turning the brake lights on.
Old Mar 22, 2008 | 12:10 AM
Jrailer's Avatar
not a fuse it runs bolth
pull the bulbs out and flip them with your finger if the eliment moves you will see the broken side of it
huyuhy
Oct 8, 2011 03:44 AM
96 jette guy
Jun 14, 2010 05:02 PM
NY_VW
Jan 19, 2006 09:22 PM
shana
Nov 28, 2005 03:03 PM
rossiross
Jul 26, 2005 08:53 PM
