B4 Passat Wheel bearing replacement
Hello, slowly getting annoyed of the wheel bearing noise and thinking whether it could be possible to change them myself. From manual seems straightforward https://www.carmanualsonline.info/vo...kshop-manual/5 however if they are stuck (pretty old) it may cause some headache. So should it be trusted to a mechanic or done home?
Default Welcome to Volkswagen Forum - Rules & Recommendations It depends how mechanically minded you are and what special tools you have for replacing the wheel bearing. |
