Add Navigation System?
Is it possible for me to add a VW navigation system to my 2006 passat? I didn't originally select this option, but would I be able to replace the current radio I have with the Navigation display? Would the dealer do this for me?
RE: Add Navigation System?
There's no reason you can't add the Nav to your car. Just depends on which one you want to install. If you want one the comes with the car as an option than yea, you can install it. Ask a dealer to do it? Yikes, big money
-Jeff |
word, the dealer is going to be expensive... do it your self or find a buddy.
tony |
Pretty much what I was getting at...do it yourself kinda deal. Might run into issues if you don't have a wheel sensor wire already run and hooked up. NAV needs that or it won't run and configure properly.
Okay, I'll look into some other navigation systems that I can save some money on. Thanks alot!
