97 passat will turn over but won't start
I am thinking of buying a 97 passat with a 4 cylinder, I believe 2.0. The owner says it just died and will not start. It turns over fine but won't fire. As I recall from my old Jetta that there are certain sensors that can cause this. Can anyone point me in the right direction.
Thanks |
RE: 97 passat will turn over but won't start
I'm not too familiar with the location of it but the crank positioning sensor will cause this if it is bad. Also i have been hearing alot of people having problems with the ECM relay. You might check this as well. The number 3 relay in above the fuse box is the ECM relay. Check out other posts on the ECM relay. They might be helpful.
Hey buddy i have a 97 vr6 im looking to just sell cause im desprite for money 5speed real nice and strong.. write back if intersted!
