95 passet clutch bleed help
ok im new here. i need help bleeding my clutch on my passat. iv replaced the slave cylinder and the master and have tried to blled it a dozen times. i was told i needed to bleed the brakes and clutch. or vacuum bleed it. does any1 know the correct way to bleed the clutch system. any help is greatly appreciated.
