-   -   2014 Passat brake check valve replacement (https://volkswagenforum.com/forum/volkswagen-passat-cc-21/2014-passat-brake-check-valve-replacement-39385/)
wtm Mar 1, 2024 10:01 AM
Im working on a 14 Passat with a 2.5 trying to replace the brake booster check valve. The new one in the picture on the top below was purchased from a local parts store but it doesnt look like the OEM one on the bottom. Will it still work?
Also, how do I remove the vacuum hose from the OEM check valve in the right picture. I can twist the valve in the hose but I cant pull it out. Thanks!
https://cimg7.ibsrv.net/gimg/volkswa...f227eb8eaf.jpg
https://cimg9.ibsrv.net/gimg/volkswa...0a7318779b.jpg
