2008 VW Passat Fuse Box
Old Jul 7, 2019 | 09:43 AM
Rebecca's Avatar
Default 2008 VW Passat Fuse Box
Does anyone see anything wrong with this picture? Thank you.
Old Jul 9, 2019 | 08:32 AM
Without look at my 2008 Passat fuse layout what is you problem?
Post moved to the correct section.
Old Jul 9, 2019 | 09:12 AM
Rebecca's Avatar
Thank you for your response. My check engine light is on. But I am worried that I put some fuses back in the wrong place. Number 24 and 26 may be incorrect. Thank you.
Old Jul 10, 2019 | 06:38 AM
e.g.
Fuse 24 - 10A Data Bus On Board Diagnostic Interface (J533)
Fuse 26 - 10A Power Supply Relay (Terminal 30) (J317)
Old Jul 10, 2019 | 09:58 AM
Rebecca's Avatar
Thank you!
hatchie
Jan 27, 2020 06:38 AM
Noelstone
May 10, 2018 07:44 AM
mcf57
Mar 9, 2016 07:25 PM
cbjacobs29
Nov 24, 2014 08:20 AM
leftys4js
Jan 5, 2008 05:37 PM
