-   -   2005 passat 1.9 tdi epb problem (https://volkswagenforum.com/forum/volkswagen-passat-cc-21/2005-passat-1-9-tdi-epb-problem-37395/)
john mcclean Jul 7, 2017 07:45 AM
fault code vag 00650
Keithuk Jul 8, 2017 06:26 AM
VAG Error Code: 00650
Fault Location:
Clutch Pedal Switch (F36) - Open Circuit/Short Circuit to Positive/Implausible Signal
Possible Cause:
Wiring/Connector(s) short to positive.
Clutch Pedal Switch (F36).
Possible Solutions:
