2005 passat 1.9 tdi epb problem
VAG Error Code: 00650
Fault Location:
Clutch Pedal Switch (F36) - Open Circuit/Short Circuit to Positive/Implausible Signal
Possible Cause:
Wiring/Connector(s) short to positive.
Clutch Pedal Switch (F36).
Possible Solutions:
Fault Location:
Possible Cause:
Possible Solutions:
JPFISHER
Jun 20, 2017 12:27 PM
