2003 Passat W8 4 motion.... throwing engine code
Code: P3081
I wasnt able to get any information on what the code meant. I'm going to google and see what comes up. Any input from experienced users on here would be greatly appreciated and very VERY helpful. I hope I can figure this out soon. |
There's a filler bung on the side of the pan. Oil must be added by a specialist. Unless there is an obvious leak, it won't be something you'll need to worry about. If the trans leaks, go to an independent Automatic Transmission Repair Specialist for advice. The VW Dealer will probably send it to them anyway!
| All times are GMT -5. The time now is 02:48 AM. |
