2002 1.8T front exhaust pipe (down pipe w/flex) removal
I notice the three flangebolts for the downpipe are not very accessable. should i remove the cat to give myself some wiggleroom for access through the wheelwell? and possibly pull up to motor compartment? has anyone made this repair? any help would be GREATLY appreciated!! the flex pipe is bad and i would just as well replace the entire pipe flex and all as one piece! Thanks |
Do you still have worry about your Navigation not working properly? It can surely be quite annoying- especially if you’re on vacation and rely on the DVD Navigation. It would take time since you have to perform major dashboard surgery. You can be rest assured that the car GPS has a good reception of radio as well as GPS signal. It provides you with smooth playback so that you can indulge yourself when the music or videos are on while other navigations often have troubles with the sound or even systems are halted.
