1997 Passat Wagon Bad Shaking from Engine
VW Passat Wagon V6 gasoline
Hi, I was given the car by my parents. The car is fine except for its bad gas mileage, and the fact that when I accelerate on an incline, the entire car shakes. I drive very gently and the engine oil has just been changed. Here are some symptoms:
Sounds like you have a transmission issue with the car. How many miles are on it? Have you ever had the fluid/filter changed on it? I would recommend doing that if not. Also have the valve bodies checked to make sure they are working properly.
| All times are GMT -5. The time now is 04:16 AM. |
