1.8T MAF Replacement.
Old Feb 12, 2008 | 02:27 PM
Pete12's Avatar
Default 1.8T MAF Replacement.
My girls car is throwing a code calling for a new MAF. We need to get the car inspected in 2 weeks, so a CEL wont exactly help us out. I was wondering if you guys have any easier methods to replacing it, or if its just as easy as doing on on a nissan. If anyone has pics or something it would be appreciated, Thanks!
Old Feb 12, 2008 | 05:46 PM
Pete12's Avatar
Default RE: 1.8T MAF Replacement.
ttt
Old Feb 20, 2008 | 03:40 PM
bagel's Avatar
Check and see if the little thing inside the sensor is broken, that will make it truly bad. The sensor is prolly dirty, is the car running ok? Clear the codes, and spray the sensor with the MAF cleaner. You will have to keep the RPM's up while spraying casue it will want to die. Spray everything, connection all that, and then see if it runs better or the code comes back.
agilbert10
Sep 26, 2009 07:40 PM
jon1270
Dec 20, 2008 08:47 AM
rolandor
Jul 4, 2008 02:13 PM
99vdubber
Jun 30, 2008 11:11 PM
gscgabe08
Apr 10, 2008 02:14 PM
