-   -   '02 Passat with short to ground codes!! help (https://volkswagenforum.com/forum/volkswagen-passat-cc-21/02-passat-short-ground-codes-help-1696/)
lrpgulf77 Oct 23, 2006 08:26 PM
I got an '02 passat with like 8 short to ground codes!! I checks the fuses and relays. i got it APR tuned, K@n filter, manual boost controller! i was installin my boost gauge and after the installation the check engine light came on and spitted out tons of short to ground codes!! i went through all the fuses and relays... what can i do now besides go to a stealership!
finbar06 Oct 25, 2006 06:23 PM
RE: '02 Passat with short to ground codes!! help
you either pinched a "hot wire" when mounting guage,or you have polartiy crossed. feel/look around for a burnt or melted wire casing.
