'02 Passat with short to ground codes!! help
Old Oct 23, 2006 | 08:26 PM
lrpgulf77's Avatar
Default '02 Passat with short to ground codes!! help
I got an '02 passat with like 8 short to ground codes!! I checks the fuses and relays. i got it APR tuned, K@n filter, manual boost controller! i was installin my boost gauge and after the installation the check engine light came on and spitted out tons of short to ground codes!! i went through all the fuses and relays... what can i do now besides go to a stealership!
Old Oct 25, 2006 | 06:23 PM
finbar06's Avatar
Default RE: '02 Passat with short to ground codes!! help
you either pinched a "hot wire" when mounting guage,or you have polartiy crossed. feel/look around for a burnt or melted wire casing.
benjibighorn
Feb 29, 2008 08:19 AM
Paul Chambers
Jul 22, 2007 01:09 PM
Paul Chambers
Jul 22, 2007 01:07 PM
lrpgulf77
Oct 23, 2006 08:12 PM
hikerboy
Aug 16, 2004 08:46 PM
