02 Passat Heater Core Replacement
Is this a task for a certified Tech, or is this some thing a DIY can do?
I had a VW Shop Quote me to do it and they wanted near a $1K to do it. I checked online and the heater Core is about $50-$100 for the part. |
is tht passat the GLX?? i can check on alldata and give u the instructions. if you would like...
Originally Posted by elrocco88
(Post 40306)
They charge alot because many things need to be removed... Hope you have the right tools...
Heater and A/C Unit - Removing and Installing CAUTION! Before beginning repairs on the electrical system:
http://alldatapro.com/alldata/PRO~V1...2269/108876052
Install in reverse order of removal, noting the following:
http://alldatapro.com/images/blnk_spc.gif© 2010 ALLDATA LLC. All rights reserved. |
You can check on germanautoparts.com. They have good prices on parts, specially VW...
