VW passat 2005 1.9 tdi fault code 00650
Old 05-20-2017, 12:15 PM
john mcclean's Avatar
Default VW passat 2005 1.9 tdi fault code 00650
fault code 00650 epb fault see owners manual/handbook
Old 05-21-2017, 08:26 AM
VAG Error Code: 00650
Fault Location:
Clutch Pedal Switch (F36) - Open Circuit/Short Circuit to Positive/Implausible Signal
Possible Cause:
Wiring/Connector(s).
Clutch Pedal Switch (F36).
Possible Solutions:
As taken from my new https://volkswagenforum.com/forum/ge...oftware-34973/
alooh2000
06-05-2010 01:50 PM
alooh2000
06-05-2010 01:47 PM
jeskavw
01-25-2009 09:21 AM
jimmylipps1.8turbo
04-27-2007 02:50 PM
jimmylipps1.8turbo
04-19-2007 07:03 PM
Quick Reply: VW passat 2005 1.9 tdi fault code 00650
