Transmission steel lines leak
Old 03-29-2018, 07:27 PM
Jacob Simonson's Avatar
Default Transmission steel lines leak
I have a 2004 Passat with the 1.8t in it. When the car is running I leak what I think is transmission fluid. When it started leaking I took the top line going into the radiator off and removed the o-rings because one was completely torn in half and the other looked like it had been pinched. So I replaced both o-rings and it stoped the leak while I tested it in my shop but the first time I went for a drive it started to leak again so I repeated the same thing but used different sized o-rings thinking maybe they expanded with heat, and again it stopped the leak while I was at idle but once I took it for the fist drive drive it started to leak again. Am I just using the wrong o-rings does it need to be a special o-ring, other wise I don't know what the issue could be because I can stop the leak for a little while. Also, when adding more transmission fluid do I need to have a special machine or can I use a small hose and syringe to force it up through the bottom fill plug? Thanks!
Old 03-30-2018, 11:47 AM
ericsfox
03-14-2009 12:17 PM
ericsfox
03-05-2009 11:17 AM
ericsfox
03-04-2009 03:11 PM
verh444
07-07-2008 05:49 AM
silver72run
10-25-2007 09:56 PM
Quick Reply: Transmission steel lines leak
