P0544 code with engine & glow lights on
Old 11-30-2017, 12:05 AM
MichaelJ's Avatar
Default P0544 code with engine & glow lights on
Hello everyone,
I am posting on behalf of my Dad whose 2008 VW Passat 2.0lt TDi has developed a problem recently.
As background, he left his car in the garage for 2-3 months and it has not been started\driven during that time.
When he got to eventually drive it, the engine and glow (the one which looks like a twirly pig's tail) lights came up on his dashboard.
Using a cheap OBDII bluetooth device connected to his car, I was able to retrieve the P0544 error code using the Torque Android app.
I would like to know whether anyone has been able to successfully resolve this issue & how. Also, is it safe to drive the car around over short distances or should the car be taken immediately to a mechanic\dealer to avoid any costly damage(s) to the engine\other parts?
Many thanks in advance.
Michael
Old 11-30-2017, 09:31 AM
This is your second post but you've posted the same question on another thread.
VAG Error Code: 16928/001348
EOBD II Error Code: P0544
Fault Location:
Exhaust Gas Temperature (EGT) Sensor 1 (G235), Bank 1 - Circuit Malfunction
Possible Cause:
Wiring/Connector(s).
Exhaust Gas Temperature (EGT) Sensor 1 (G235).
Engine Control Module (ECM).
Possible Solutions:
Read Measuring Value Blocks (MVB).<br />Check/Replace Exhaust Gas Temperature (EGT) Sensor 1 (G235), Bank 1.
As taken from my new As taken from my new EOBD II Fault Codes Software
Ables
11-29-2017 11:48 PM
sonchoo
06-15-2008 11:00 AM
mtnbug
11-21-2007 08:34 PM
borabora
07-28-2006 12:08 AM
woodbutcher1953
06-05-2006 10:20 AM
Quick Reply: P0544 code with engine & glow lights on
