2005 passat 1.9 tdi epb problem
Old 07-07-2017, 07:45 AM
john mcclean's Avatar
Default 2005 passat 1.9 tdi epb problem
fault code vag 00650
Old 07-08-2017, 06:26 AM
VAG Error Code: 00650
Fault Location:
Clutch Pedal Switch (F36) - Open Circuit/Short Circuit to Positive/Implausible Signal
Possible Cause:
Wiring/Connector(s) short to positive.
Clutch Pedal Switch (F36).
Possible Solutions:
JPFISHER
06-20-2017 12:27 PM
john mcclean
05-21-2017 08:26 AM
JW PASSAT
02-20-2014 10:52 AM
Kevinkate
08-25-2013 08:13 PM
L.H.D.2
12-03-2009 02:19 PM
Quick Reply: 2005 passat 1.9 tdi epb problem
