2002 passat estate problem with gearbox?
Old 05-28-2012, 01:58 AM
Lynsey Seasonal Król's Avatar
Default 2002 passat estate problem with gearbox?
Hi, wondered if anyone could shed any light on the problem im having, weve only had the car just over a week, we had to spend £360 on it on the 4th day, because it started to make a screeching noise when turning the wheel. the garage replaced every belt imaginable. we thought it was all perfect but this morning when coming home from work it did something strange, i reversed from my parking spot ok, but when i put it into drive (its an automatic) it kind of jerked, I put it in park and tried in drive again 4 times, each time it did this jerk thing but drove ok, then I also noticed that all the lights on the dash were lit up PND1234, whereas normally only the d is lit up, i tried going up and down the gears (its tiptronic) to see if the display would change, but all the lights remained on.
the car is a 1.9tdi estate auto sport.
if anyone knows what this problem is (hopefully its not a big one) any help would be greatly appreciated, I'm hoping we haven't had a duff deal.
thanks
Old 08-01-2012, 07:52 PM
2mev19ls1VR5's Avatar
Hello! I discovered the same issue on my tiptronic two weeks ago. I called to a workshop and they called the problem a tiptronic emergency operation on the gear system. I hope to get my tiptronic up running as fast and safe as possible so i am checking with everybody i can for information. After checking other sites where its written a little bit of the issue i am quite sure that it is nothing more than an electrical error to protect your gearsystem while you getting your car to a workshop so they can look at it. Hope this helped you and your tiptronic please reply and comment how it went and how you fixed it
Old 08-02-2012, 02:10 PM
it turned out to be the transmission range selector switch, we had it done at a garage and it sorted the problem out, its just our turbo thats knackered now lol, but thats another story
02-25-2011 12:41 AM
12-18-2010 03:45 AM
kentpassat
07-12-2010 10:40 AM
creaturestudios
12-18-2006 10:14 AM
oystermax
11-29-2005 06:01 PM
Quick Reply: 2002 passat estate problem with gearbox?
