1999 passat surges and jumps into gear - Volkswagen Forum - VW Forums for Volkwagen enthusiasts
Reply
Thread Tools Search this Thread
Old 02-04-2011, 04:12 AM
Default 1999 passat surges and jumps into gear
1999 passat 6cyl has CEL brake ABS oil symbol and battery lights on. Recent oil leak in front of engine . Repaired already. New battery put in. Has problems with missing when slightly throttling. When idleing no problems noted. Does have horn blowing unless removing positive battery post a few times with someone else turning engine over. Also noted to sputter and surge when accelerating and will progress to point that it jumps into next gear after whining out. Does have a sun looking symbol on left bottom of instrument panel with MAF next to it. Does that mean anything. Does have a number that changes as driven in same vicinity, is reading 26-29. Any suggestions or questions I will keep checking. Thanks in advance.
Reply
Thread Thread Starter Forum Replies Last Post
87, cabrio will not go into gear, and has a lot of play in the clutch. Robin Hood Volkswagen Cabrio 1 07-18-2015 08:34 AM
Car wont shift into reverse, 1st and 2nd gear not working properly dirtykurte Volkswagen Jetta/Bora 1 08-04-2010 11:18 PM
slipping out of gear into lower gear tarts052 Volkswagen Jetta/Bora 0 05-26-2008 08:02 PM
Having trouble getting into 1st gear! tamvervan Volkswagen Golf 3 03-01-2008 06:43 AM
92 Passat surges terrym Volkswagen Passat 1 06-04-2006 10:47 PM
Tags
02, 1999, 99, accellerating, gear, passat, passet, surges, surging, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
