Whats are the fuses underneath the hood (by the battery) for?
There are two slots and one fuse is in (20 amp...i know what its for now) and one is empty.
Whats the empty slot used for? Cruise control? 97 VW Jetta 4 cylinder 2.0 |
RE: Whats are the fuses underneath the hood (by the battery) for?
one is for coolingfan a/c
no oncruse control it is in the main fuse box |
Yeah thats the one I knew about (cooling fan) and I figured the cruise control was in the main fuse box.
So what's the other slot for? Is it supposed to be empty on purpose? Thanks. |
alot of times thay use the same fuse box on different cars to save money. it may be for some acsesery on some other car. but idono.
if its empty and everything works i say dont worry bout it. but i know if u r anything like me u will ;) |
Its not in the main fuse box.
It's near the coolant and the battery underneath the hood. Completely seperate from the main fuse box located under the steering wheel. Thanks anyways. |
yes they do use the aux fuse box on the battery on diffrent modles
some do fill all three spots and some dont |
Ok. Thanks.
Two spots..not three though. |
What is a fuses box called ? Mine started to smoke...
Originally Posted by Timetogetill7
(Post 14102)
| All times are GMT -5. The time now is 03:20 AM. |
