-   -   weird problem with door locks (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/weird-problem-door-locks-36168/)
vwjetta11 Dec 8, 2013 11:49 AM
im new to this forum. I have a 2011 VW Jetta 2.5L gas and my question is just this last week the car has been acting up what it does the door locks keep locking when your driving the car and when u get out of it the drivers door don't open u try unlocking it, it still don't open. do any of u guys had this happen before or have any idea whats wrong with it? thanks
Keithuk Dec 8, 2013 08:22 PM
1 Attachment(s)
Welcome to the forum. Attachment 2713
Yes its called auto lock that locks all doors when you drive above 10 mph. Its an annoying feature which I turned off in the MFD settings. Now someone asked about disabling this feature on his 2011 Jetta on another forum. He said there where no options in the MFD settings to do that on USA models.
If you can't find anything in the MFD settings then you need to find someone with VAG-COM\VCDS to disable this feature. It appears that dealers won't disable it as its a safety feature.
If its still under warranty and the drivers door won't open when stopped get it fixed under warranty.
vwjetta11 Dec 9, 2013 06:48 AM
I know it auto locks but it keeps locking while ur driving and then when u put it in park the drivers door won't unlock u try to unlock it it won't let u and it don't have warranty anymore
Keithuk Dec 9, 2013 07:12 AM
So it locks and unlocks while you driving then when you've stopped you can't open the drivers door?
You need to get your motor scanned for any error codes logged in the ecu and post them.
If your in USA I'm told AutoZone will do a free scan in the hope you buy something of them.
vwjetta11 Dec 9, 2013 07:19 AM
It's not throwing any codes but I will hook my code read and see if there's anything after work
Keithuk Dec 9, 2013 07:41 PM
Which code reader do you use?
