want to change battery, will I need a radio code?
Old Dec 11, 2006 | 11:23 AM
ewarnerusa's Avatar
Default want to change battery, will I need a radio code?
My wife owns an '01 Jetta Wolfsburg Edition 1.8T. It starts very weakly in the cold weather, so I wanted to try changing the battery to see if that helps. We are not the original owners of the vehicle. It did not come with an owner's manual, but I bought one off ebay. The manual says that changing the battery will likely put the factory stereo into Safe Mode and I'll need the security code to enable it again. I don't have this code. Will I definitely need it and is there a way to get this code looked up for free? Thanks.
Old Dec 12, 2006 | 05:49 AM
vwsleeper's Avatar
Default RE: want to change battery, will I need a radio code?
i really don't know because i have a 05 gti, but i disconnected the battery to try to reset the ecu and when i hooked the terminal back up my radio worked without having to input the sercurity code.
Old Dec 12, 2006 | 11:34 AM
ewarnerusa's Avatar
I called our local VW guru and he had a clever scheme which worked. I used an emergency jump starter, the kind with alligator clamps like jumper cables, and clippped them to the battery posts before removing the old battery. So the system was never unhooked from a power source and no electrical items were reset during the swap.
Old Dec 12, 2006 | 12:10 PM
vwsleeper's Avatar
hey that's pretty nifty, never thought about it that way. smart guy
Old Dec 12, 2006 | 12:52 PM
ewarnerusa's Avatar
I thought it was pretty clever, too. The guy at the shop apparently uses the kind that just plug into the cigarette lighter and that would have made it even more painless.
Old Dec 12, 2006 | 01:02 PM
Joelzy's Avatar
whoa... thats clever, have to remember that one thanks
Old Dec 13, 2006 | 06:10 PM
  #7
heavenly_blade101's Avatar
Yeah man.... but about the battery, my dads was really weak but when we gave it a full charge it went back to normal. Maybe thats all yours needs???
Tana1029
Feb 20, 2012 08:02 PM
fresh188
Feb 16, 2012 07:39 PM
VWblack
Jan 29, 2012 04:10 PM
mkbomb
May 19, 2009 08:59 PM
redoo
Jul 31, 2006 11:39 PM
